Re: Hesitation when accelerating hard
I have a 1993 3.0L Merc doing the exact same thing you are describing. There is a lot to be said for fuel injection! I have also rebuilt the carb, changed plugs, plug wires, filters, etc. to find the accelerator pump remove the flame arrestor from the top of the carb. Look down the throat of the carb while some pumps the throttle a couple of times. You should see a strong blast of fuel. You probably replaced the accelerator pump when you rebult the carb. It was the white plastic piece covered with a spring. I noticed the new pump was more "stout" then the old. Unfourtunetly I still haven't found my problem. The only thing left for me to try is replacing the fuel pump. <br />Good luck, let me know what you find when you figure it out!!<br /><br />Jeff
