royal0014
- Joined
- May 6, 2010
- 874
Johnson SuperSeahorse RK-28B (1966) Electramatic 40 horse.
So I'm gonna rebuild the spare carb I picked up on Flea-bay last year. Please refresh my memory, 'cause I can't seem to locate the cd-rom with my manuel on it.....
As I remember, the high-speed 'jet' is a fixed orfice in the bottom of the bowl, behind the drain screw. It could be removed, if you have the right size screwdriver. It was pretty gunked up in there, with a hole through the middle. It actually looked like there was no orfice in it, but I could not tell for sure. Got the bowl soaking in carb cleaner, I'll get a better look tomorrow.
Also, I pulled the low-speed needle to see if it needed replaceing. Nice and straight, no wear at the seat. But there is a tiny dimple on one side, in the middle of the point. Hard to see, but I can feel it with a fingernail. I'm thinking a real light shining up with some 1200 grit, or would that be asking for trouble?
Thanks for the help.
