Hey RRitt...
smac1484
could you check out my post for frank & john ...i need help,I actually need your input.Its a question about a link you sent me...thanks
RRitt
Re: Hey RRitt...
a square bridge rectifier is just four diodes connected in a square with a wire attached to each corner. Use the diode setting on your multimeter to check each individual diode. If all four diodes are good then the bridge rectifier is good.
smac1484
Re: Hey RRitt...
what i actually wanted you to answer was about the link(sea-way) you suggested to me .Is the parts you put in the link the correct ones for my engine or will i need to spcify to seaway ....thanks
