Hi guys, it's me again. I think I may be being tested to see how many problems I can endure with my boat here. I bought this boat a year and a half ago and have been working on it pretty much ever since. It's a 26' glasstream seaquest. I installed a mercruiser 888 (ford 302) drive in it. I bought another boat with an 888 drive to have spare parts.
Long story short, I've been in my engine three times. This last time I took it to the machinist and told him to do the machine work AND assemble it(bottom end and heads). I picked the engine up about october. I finally had time to get it ready to crank friday. This time it's got a lunati cam in it with the firing order of a 351w. I installed a new tach where I could break it in correctly without guessing the rpm. (machinist said 2200-2500rpm for 15 minutes or so) I got the engine fired up, ran it for 15 minutes, then let it idle as I adjusted the idle screw on the carb. Engine sounded good as far as I could tell. Everythings great, checked the oil, looks like milk.
The engine has not had water in it until friday. I plan to call monday to see if he checked it for cracks(block and heads), although I'm reasonably sure he did. I replaced the intake with a 4 barrel cast iron unit, is it common for a 302 intake to leak water into the pushrod area? I am beyon tired of pulling this engine. It sits down in the floor and is no fun to play with.
And yes, if the engine has to come out it will be tested outside the boat on a stand. I just thought everything was gonna be good to go this time.
