hi I'm in the process of restoring my boat.
bchavez
hi I'm in the process of restoring my boat. But i I'm having trouble finding parts. I have a 1977 sea ray srv 200 it has a ford v8 235 hp an I'm looking for the hole wire harness. Does anyone know where I can get one
Mark72233
Ensign
I have been restoring my 1972 Thunderbird Formula for the past 18 months. I have purchased an engine package I found on eBay, a donor boat with another engine package I found on eBay and tons of original items from eBay by searching for NOS (New Old Stock) boat parts. Local Craigslist and similar websites also.
gm280
:welcome: bchavez to iboats... Nice you could join us...
What seems to be wrong with your wiring harness? Is it is just some connectors or such, you may can find replacements. JMHO!
bchavez
Thank you all for your post. I have try looking in ebay an cragslist.
I found some wires that plastic was cracked
gm280
If you can' find the harness replacement, you can order marine wire in most any gauge and color and make up your own harness. It really isn't that hard to do. JMHO!
avolnek
A boat of this age youll have a hard time finding a relacement wiring harness let alone a harness in good enough shape to really be worthy of replacing yours. As mentioned you can order marine wire so it'll match the operations of each wire appropriately and replace either your whole harness or replace wire by wire. My boat had some bad wires so I did just this. I cut the bad wire, taped my new wire to it and drug the new wire through the loom via the old wire I was replacing.
