Hi Starcraft fans !! I need the white rubber bumper strip on my boat replaced .
rbozzi
I have a 1973 Starcraft Arrow that need the white rubber bumper that goes around the border of the boat replaced . Is that a hard job and were do i get the parts to replace it ? Thanks for your help . I have better pics coming soon . This is the back of the boat . But you can see the rubber bumper in the pic . I also need that piece of aluminum trim on the corner .
Picture 434.jpgRon
N1265
Re: Hi Starcraft fans !! I need the white rubber bumper strip on my boat replaced .
What you are looking for is called the "rub rail" the insert is easy to replace as long as the allumin rail is not all bent up. simply take that screw out, then remove the cap at the bow and make sure there is no rivit or screw under the cap, then simply slide the insert out...
finding the missing alum piece that goes at the rear is a PITA, you may have to fab up a replacement " end cap" on your own...
rbozzi
Thanks for the info guys !!
