Re: high 5 prop efficent? how about gas mileage
The more blade surface area, the more hook up you have, and less slippage. Think four wheel drive.
The penalty for increased surface area is more drag. A three blade prop is the best all around for a reason, and will usually give you better fuel efficiency.
Those who choose 4 or 5 blade props are usually big watersports folks, and are gladly sacrificing a little bit of cruising efficiency for massive hole shot capability in the zero to 10 knot speed range.
Unless you have a loaded boat, and are pulling slalom skiers, the 3 blade is a better all around choice.
Let the debate begin!
