I have a 1983 3.0 140 hp with delco-Remey alternator. The engine has been upgraded some time back with electronic ignition. At the end of last season my alternator showed a low charge rate so I bought a new one and installed it, everything was fine for two weeks. Then the new alt showed a reduced chg, but it was end of season so I put the boat to bed for the winter. Over the winterI was checking the wiring because the battery switch was not switching between the two batteries. Found the switch was not wired correctly along with a few other things so wiring was corrected per the mercruiser manual. Boat runs fine and battery switch functions correctly but now the alternator shows a 15.3 volt output all the time. Took the old alternator to our local guru who rebuilds these for the past 30 yrs and he completely disassembled the alternator and checked out each part, cleaned everything, replaced all the nuts and screws with new ones, cleaned all contact points and checked it thoroughly on his machine. Alternator is performing perfect. Put the just checked Delco unit on and still showing 15.3 volts output. Battery has a 13.04 charge and second battery shows a 13.3 charge at rest. Batterys are in great condition, voltage regulator was checked carefully as i had explained the problem to the repair person. Have checked and cleaned all conections, alternator shows 15.2/15.3 right at the post on the back of the alternator when running. What now? As always many thanks in advance for the excellent suggestions I get from this forum.
Airshot
Airshot
