High Altitude Jetting
like.2.fly
I know this is an OLD thread, but I have a related question. I found the high altitude jetting chart in my service manual for a '96 Mercury 125hp. It has suggested sizes for various altitudes. The motor is going from near sea level to 8800' where it will be used almost exclusively from now on. I know the carbs need smaller jets, and prop needs less pitch. I'm a bit confused on how to read this jet chart. It says factory jets are usually ok up to about 5000', but after that they should be reduced according to the chart. So the chart gives the factory jet size, and what it should be reduced to for every 1000' of elevation gain. My question is, is that chart for every 1000' above 5000', or every 1000' above sea level? If I read it the first way (every 1000' above 5000) then my jets would go down from the stock sizes .070,.080,.078,.082 to .068,.076,.074,.078. But if I read it the second way (every 1000' above sea level) then the jets would drop further to .064,.072,.070,.074. Which one is correct?
like.2.fly
