High Elevation Prop Selection
bbigelow0763
Looking for advice on which prop to use on my bass boat.
1998 Tracker Nitro Savage bass boat
18? 6? long
1998 150 EFI 2 stroke
Current prop ? Mercury Laser II 48-16546 ? 21P
Was being used at around 4700 ft asl To be used at 5,500 ft ASL
Using it to fish and pull tubes and skiers
jimmbo
Welcome to iboats
You are only going up another 800 ft. What is your engines full throttle RPM range, 5000 - 5500? Unless you are currently running at or near the bottom of the range, I wouldn't be too concerned. If a the bottom end or lower, get a 19. Do you have a spare prop? I so, what is its pitch?
Edit: Were you using it to pull tubes and skiers at the lower altitude? How was its holeshot? Any problems pulling up the skiers?
