Re: high five prop on 3.0l
Unless the boat is used for pulling skiers, tubes, or wake boards constantly, I am not a fan of four and five bladed props for a few reasons.
One, the low end performance (acceleration) may improve but is near certain that the top end will suffer. In addition the boat will be more prone to have a torque list at cruising speeds.The most common way to increase top end is to increase the pitch (ie: move from a 17" to 19") but stay with the three blade. The flip side of this is that the boat performance will suffer during acceleration, especially under a load.
Supreme Mariner, suggested that the use of our trim tabs may give you more top speed. Three things will help you achieve your goal of more top speed and maintain the towing performance. One, use Smart Tabs to improve acceleration with minimal bow rise. Time to plane will be cut nearly in half. Two, move from the 17" prop to a 19" three blade. Three; MAKE SURE YOU TRIM OUT so that the prop is perpendicular to the water surface when at speed. Currently you may incur porpoising when you trim out, but when properly adjusted the Smart Tabs will eliminate the porpoising when you trim out more.
The better trim angle, increased prop pitch, and smoother ride should give you another 3 MPH or more. Fuel economy will improve as well since the engine turns fewer rev's per mile with the 19" prop and less up hill struggles during acceleration.
