I have a 97 Cobalt 190 with a Mercruiser 4.3LXH 205 php engine. Dry weight is 2,850 pounds. It has a 14 x 19 stainless steel 3-blade prop that produces 50 mph at WOT of 4,500 RPMs. The recommended WOT range for my boat is 4,400 - 4,800 RPMs. Unfortunately, hole shot is poor for skiing. From some other posts, I have seen that the Merc High Five prop is great for improved hole shot. My question is, should I get a 17 pitch High Five or a 19 pitch High Five? I have heard that it is better to prop toward the top of the RPM range, which makes me think that the 17 pitch would be better since I am currently in the low end of the range. However, I wonder if the 17 pitch would cause me to exceed the top end of the range slightly and, if so, is that much of an issue? Any thoughts on prop receommendations with anticipated RPMs and top speed would be appreciated. Thanks in advance.
