Hi All,<br /><br />I have just purchased a 19ft bowrider with a 260hp V8 MPI I/O. The boat comes standard with a 3 blade aluminium prop. I know you old heads in this forum probably get asked this question quite a few times, here goes.<br /><br />The boat weighs fully laden with fuel, 6 or 7 lard *** blokes, gear etc is approx 4000 lbs. Our main use will be wakeboarding, tubing and cruising, so good hole shot is our objective without sacrificing too much top end. Basically a good comprimise.<br /><br />How do the high fives go?<br />Can you guys recommend a prop / pitch / cup etc that will suit our needs.<br />Any help or knowledge would be great.<br />Thanks <br />
