Okay holy moly, FML. I found my problem and it seems very bad. a butterfly bolt is missing, hopefully it shot out and not into the engine....The butterfly seems warped also...what do I do guys. Is it safe to run this motor if it's possible there a screw in the cylinder?
DO NOT run the engine in that condition. You need to replace the missing screw. At a guess, I'd say someone was 'servicing' the carb, removed the screw (which you shouldn't do unless you are replacing the plate or the throttle shaft) and didn't peen it over when they replaced it... :facepalm:
You can buy a new screw. Loosen the other screw slightly and run the new one down until it's just touching. Jiggle the plate and snug one screw, then remove the other and put the Loctite on it, run it down and tighten it, remove the other screw and do the same (Loctite)... I also like to peen the end of the screw if you can reach it.
For the screw the part number is 10-F10155, but be warned, they are very expensive
$1.80....
Remember to set the carbs up properly when you put it back on...
As for where the screw went.... Anybody's guess... Could still be in the engine (and unless you do a full strip you won't know)... Could have been 'digested' by the engine and shot out the exhaust, could have fallen out and into the air box (I assume you have checked that one)...
Chris.........
