High spedd / low speed orifices
bigcat33
Can anyone tell me what thease are for? What they control? My manual is a little vauge in this area?
Silvertip
Re: High spedd / low speed orifices
High speed = high speed operation. Low speed = low speed/idle operation. If engine won't idle or idles rough, its a low speed jet problem. If engine does not run at high speed, its a high speed jet problem. Would also be nice to know what engine we are talking about.
bigcat33
Sorry, 1975 Rude 115 V4, this engine has trouble, at a lower idle she dies, like when trying to go into gear. I just wanted to know if maybe that is something that I should replace during the carb rebuild, or if a good cleaning usualy takes care of this?
Joe Reeves
(Compression & Spark Test)<br />(J. Reeves)<br /> <br />1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.<br /> <br />2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On magneto ignition systems.... and also the Battery Capacitance Ignition system OMC engines from 1968 to 1972, set the gap to 1/4". On the solid state OMC ignition systems from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!<br /> <br />If there was no spark, on engines from 1973 up, disconnect the RED main electrical plug at the engine. Remove the s/plugs. crank the engine via the starter solenoid (jumper bat term to small 3/8" term nut, not the ground nut) and observe spark. If spark is now okay as stated above, the usual cause is a shorted ignition switch.<br /> <br />If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to one or both of two things. The carburetors are fouled, in which case the cure would be to remove, clean, and rebuild them..... or the timer base under the flywheel is sticking which would result in a retarded spark.<br /> <br />To check the timer base for sticking (Engine Not Running), spin the prop to align the shifter dog with forward gear and while doing so, put the engine into forward gear. Now, while watching the timer base, slowly apply throttle clear up to full throttle. The timer base should move smoothly all the way up against the black rubber cap that is atached to the end of the full advance spark setting screw. If the timer base sticks, find out why and correct that problem.
