Re: high speed miss
well I took it out again today and it started out running farely well and as time went on it got worse. It started out running up to 4000 rpms with no problem but later would only get up to 3000 because of the bad miss. It is a intermittent miss that gets worse when I hit the trim button.The battery seems to have a good charge/I've got new plug wires on the way and I hope it helps/
Like is said in my first reply, plug wires CAN cause a high speed miss. But with the added information you have given, I doubt that is your problem.
Are the battery cables in good shape, I have found lots of cables that were tight on the battery, but the cable ends were loose or corroded so bad the engine would barely start. Look at both the Positive and Negative cables, throw away the wing nuts on the battery and use regular nuts and tighten them down with a wrench.
Get the battery load tested, and make sure the alternator is working.
Also watch around the coil tower for arching. May have some carbon tracking or crack that will allow it to fire to the smaller terminals on the coil. A plug wire with high resistance or an open will cause the arching on the coil.
