Johnson 1997 115hp
Was running great until i overheated.
Replaced head gasket, ran well until battery drain.
No tack or charging, replaced regulator and rewrapped wires
found toasted.
Tack works but volts at 10.9 -11.4.
Will idle and troll, but when up on plan will only
last 1 minute or so before drops down to idle
speed and then picks up on it own again. Will plain
longer if trolling a while.
Changed fuel filter, no change in problem.
Is this electrical or fuel?
thanks Mike
found toasted.
thanks Mike
