High vacuum warning switch usefulness?
Rkrough
On my 1987 60hp I had an issue a few days ago with the motor suddenly cutting power at high rpm and stalling at idle speed . I searched this forum and using the factory manual test procedures this morning found low fuel pressure from the VRO. (ignition checked out ok)
I'm weighing whether I want to replace the VRO or convert to a conventional pulse pump. Since the manual also covers the 65 hp commercial motor with a conventional fuel pump I have been looking at the 65hp parts diagram as a guide. The 65 hp has a vacuum switch (#0397904 @$40)to warn of fuel supply restrictions.
I have a remote canister filter/separator, I'm wondering if the vacuum switch would be of any practical use on my 60hp?
boobie
Re: High vacuum warning switch usefulness?
What's the model # of that 65 hp commercial mtr you found ?? I want to check out this vacuum switch as they are normally used on V-6 mtrs.
Rkrough
The pictures in the OMC manual shows it on non-vro models 65wmlb , 65wmyb and on VRO model 65wmlcu
Edited .....
I would post an image from the parts fiche but looks like the website name is blocked by iboats :rolleyes:
boobie
Thank you.......
boobie
I found it at another source, thanks again. You learn something new every day.
