My volt meter needle has always been strait up. (Middle Of Gauge) This year it is always in the high range (Think it says over 15 Volts) that is denoted by a crosshatch pattern on the gauge face. She starts and appears to run fine but I just don't want to get stuck. I will check all the cables and connections but wanted to know if a bad battery would give these symptoms. If not what else should I check ?
Thanks
Thanks
