Re: High Voltage
1. The excess voltage doesn't seem to hurt the battery in my boat, the one in it now is 4 years old and still working fine.
2. The high voltage is just because there is nothing drawing on the system, and the surface charge builds up, like I said before, the system is "unregulated", and they all build high voltage like that.
3. An automotive regulator will not help on this system, but you can use a voltage regulator like motorcycles use, the kind that direct excess voltage to ground. It is only a 6 amp system so not hard to find a regulator that can handle that, just need to locate it where it can air cool.
I hope this helps.
