Bt Doctur
- Joined
- Aug 29, 2004
- 19,480
the official tool slips, std. allen wrench slips.is there an "easy out" available and where?<br />mail drop EJDSR251@aol.com
If its a Pin, then its in a hole, Correct? and if you heat the pin wouldn't it expand tighter in the hole?The only other Trick I can think of for doing this kind of job On-Site,....<br />Is to drill a small hole Clean Thru the pin,....<br />It helps Relieve it,+ allows application of Heat to the Inner parts of the Pin.........
With a Hole thru the offending part,......<br />And a Fine Neutral Flame on a Small Blue Tip Wrench,.............<br />The Offending piece is Heated,..... Hot,...... Very Hot,........<br />And,.....<br />Quenched...........<br /><br />That Shrinks it...........<br /><br />Another way to the Same Place is to use a Stick Welder,........You can use the Welding Rod as a Handle to get the broken bolt out.......<br />I posted a small post about doing That on a 3.0l Broken Starter Bolt.......If its a Pin, then its in a hole, Correct? and if you heat the pin wouldn't it expand tighter in the hole?
