Hit a wake and motor cut out
robsteinny
Here's a good one. My Montauk has a 1990 Merc 75hp. I hit a wake. When the boat pounded down, the motor cut out. It would not start back up.
I checked the gas supply from tank to carb and it seems to be getting gas.
Any thoughts?
bryancx94
Re: Hit a wake and motor cut out
Check your gas hose again, from the ball to the engine. Mine comes loose often when jumping wakes. Just need to push it back in, pump the ball, and everything is ok.
tashasdaddy
do you have a kill switch. could have come loose.
robsteinny
Thanks guys. I traced gas all the way to the carbs. There is no kill switch.
tashasdaddy
check your wiring harness plug.
