Got a leak in my just bought SF14L. I was out on the river the other day and hit something floating just below the surface, I heard it thump the bow while going about 15 mph, I cut the motor and heard it drag along the bottom. I floated over it, and it popped out behind the outboard after a bit. I couldn't tell what it was but it looked like a 2x4 that was floating down stream, it was gone behind me before I could get a look. I didn't think anything of it at the time, the noise wasn't enough to really concern me and I cut the motor fast enough that it never touched the prop. I fired the motor up and went on. We fished for another 3 or so hours and after a bit I noticed a bit of water accumulating in the boat, but not a lot. I just thought it was either rain water that may have gotten in over the past few weeks of storms or from fish being brought in the boat. I also had the live well full so it too was slopping over a bit. Anyhow, after putting it back on the trailer and dumping the live well at the ramp, I pulled up to tie the boat down and noticed a pretty steady trickle of water running off the right side.
I found a 20' long deep scratch, or more of a light dent from front to back about a foot below the water line, it runs the length of one pair of ribs. It looks like a mark a dull nail would make if you pushed hard enough to slightly indent the scratch. Where the scratch ends it gets deeper and punctures the aluminum just past the rivet holding a rib in place. The puncture or leak is inside the rib, where I can't get at it on the inside. Part of the head of the one rivet is chipped off as well. The water was running out of the end of the scratch.
Only the last inch of the gouge concerns me, the rest didn't even penetrate the paint. The one rivet will need replacing but what would be the best fix for the leak?
I'm thinking of sanding the area and using JB weld over the leak and banging in one rivet. To replace the rivet, I'll have to remove the floor and possibly half of the split bench seat which will mean more rivets on the side will need to be redone. I can't see how they got the one piece floor in place without the seats being out of the boat at the time?
I can get a few pics but it was too dark by the time I got home.
My concern is with JB Weld sticking permanently to the aluminum underwater? Will it adhere to bare aluminum or is there a better fix?
I thought about a weld but figured I'd end up fixing the pin hole but end up loosening more rivets nearby or warping the hull skin in that area.
If it wasn't within a rib I'd consider just drilling it out to 3/16" and banging a rivet in the hole but to access the other side the floor has to come out.
