I couple of months ago I hit a object in the water that brought my boat to a real quick halt. I was in 30 feet of water but was later told that their were some rock piles where I was cruising and was likely the culprit. Anyways, the prop nor the shaft will spin with it in gear. It actually free spins in gear. Is there a gear or mechanisim that would likely break when hitting something and if so what? How difficult is it to take apart the lower unit and put back together to find the problem? The hub of the prop was not broken. Any advice would be greatly appreciated. Trying not to spend a ton of money to get it back on the water!!
