HITMAN FORCE 120
lonewolf5347
HITMAN THE DAY IS NOT GOING SO GOOD. JUST INSTALLED THE POWER PACK SAME PROBLEM WHAT NEXT STEP. STATOR ? OR TRIGGERS . still no fire on 1 @ 2 cylinders
Hitman65
Re: HITMAN FORCE 120
Lonewolf,<br />Can you wait until tommorow? If so what I will do is bring the book in and give you the exact voltages at the coils and out of the stator. that way you can troubleshoot it down the stator or the trigger. <br />Let me know ASAP so can get it. The manual that is!
lonewolf5347
HITMAN I DONT HAVE ANY OF THOSE METERS EVERTHING IS BY TRIAL @ ERROR @ THE ERROR IS DID NOT NEED THE SWITCH. SO WE STILL KNOW THAT 1 @ 2 STILL WON"T FIRED UP. SO KNOW THE ONLY THIN LEFT IS THE STATOR OR THE TRIGGERS IS THAT CORRECT? SO THIS IS WHAT I DID THIS MORNING WE KNOW THE TRIGGERS ARE GOOD ON 3 @ 4 CYLINDER I SWITCH NO 2 TRIGGER WITH NO 3 TRIGGER STILL NO 3 FIRED/ SO KNOW WE KNOW 2 3 4 TRIGGERS WORK . THE STATOR HAS 4 LEADS TO THE SWITCHBOX SOLID RED @ BLUE GO TO THE TOP OF THE BOX THE BOTTOM STAKES THE STRIPE THAT FEEDS 3@ 4 SO I WOULD ASSUME IT IS IN THE STATOR ON ONE SIDE. ? I HERE THAT THEY HAD TROUBLE WITH THE YRS. 1992 THROUGH 94 DO I ALSO HAVE TO GHANGE THE RECTIFER ?
Hitman65
The one I did the other day had only one stator. It covers all the inside of the flywheel. The four wires come out and the one I had (new stator)had a little black box the instructions called an adapter. It gave specific directions on how to hook it up to various motors. so you should not need the Recifier. It sounds to me now like half of the stator is down. Its to bad you dont have a volt meter. that way I could walk you through the troubleshooting and you could be sure you had the right thing. So sorry! It almost has to be the stator now that you have swapped everything else.'<br /><br /><br />Good Luck,<br /><br />Let me know how it comes out.<br /><br />I will be back on here first thing tommorow morning at about 0700 E.T. <br /><br />Hitman
