Re: hitting floating logs....
no joke, wondering more about the things that arent as noticeable as a broken prop or a busted l/u.....more like things that could knock loose or bend without standing out dramatically at initial visual check. my story isnt that horror story you are thinking.I had slowed to idle to pass some fishermen in a semi narrow section.I had just got the boat on plane when I saw it, no time to swerve.fished for 3 hours & rode 15 miles back upriver & everything seemed fine upon visual check on the water and on the ride back....until I idled up the slough to launch.after runing idle speed for about 4 minutes I got the overheat alarm.<br /><br />steelspike, the river I usually fish is always full of 5 to 6' usually around 6" diameter floaters, mostly very visible & kept pushed to the shore by traffic.I just caught one of those waterlogged ones that hang right under the surface. still waiting on an address to send that manual to if you still want it.
