Hitting Under Water Objects When Mtr Locked it Place
John6012
I have a 9.8 Nissan and I think that it would be safer to disengage the tilt-lock when boating due to the possibility of hitting underwater obstacles. I'd hate to hit an object and tear out the transom. What do you think? And how would I disengage the lever other than tieing it in place? (I hope I'm in the right topic/subject area).
Silvertip
Re: Hitting Under Water Objects When Mtr Locked it Place
You are correct that the motor can't kick up if the tilt lock prevents that. On the other hand, if you try reverse with any amount of power the motor would also kick up. A reasonable person would say -- allow the motor to kick up when striking a submerged object. If you need to fabricate something to accomplish this by all means do it.
Paul Moir
All the outboards I've seen have a mechanism to release the lock in case of strikes. Johnny/Rudes used to use a spring loaded tilt lock to accomplish that, I've seen some others that have a obvious failure point designed into the lock. I'm sure your 9.8 has something similar.<br /><br />That said, when I'm expecting to strike bottom, I usually pop off the reverse lock (if possible).
John_S
I have a Nissn 18E and 40C. Both have a lock release levers. I run some shallow rocky rivers, and almost always have the lock released. It became a habit, and run that way on most lakes. It is on one side of the engine or the other. Both of mine are dis-engaged by pushing down on the lever. Check your owners manual for how to dis-engage the lever on yours. See the Nissan or Tohatsu website if you lost your owners manual. <br /><br />Besides reverse, you need to come off plane, not all at once, or the motor will kick-up. You will hear it when it does. When the end of the prop clears the water, you are running open exhaust. ;) In reverse, just cut back on throttle, and motor will drop back down. Coming off plane too fast, will do it by itself. The water pick-up can be out of the water when the engine kicks up, so don't want to be running that way for very long.
JB
Outboard Non-repair topic
timmathis
Not so good on props either way best if avoided.
rodbolt
most all modern outboard locks and trim assemblies have a provision for unlocking at impact.
Texasmark
Thing about the release is that it takes time for it to mechanically function.....time that your boat is moving forward across the thing that you hit. We're talking about split seconds here, but at 25 miles per hour split seconds can mean feet (didn't calculate).<br /><br />With it loose you don't have to wait so long as it immediately starts to raise.<br /><br />I used to have engines like that and I'd leave it released unless I was backing up....then lock, and unlock as soon as I was through manuevering.<br /><br />The thing that convinced me was running a '60's vintage 10 hp Scott Atwater on a john boat down a river. Ran across the submerged pilings of an old railroad bridge and split the lower unit half in two. When the boat stopped, the only thing holding the lower half in place was the shift cable (clamp actually).....not a good feeling.<br /><br />My 2c,<br /><br />Mark
rodbolt
and by the same token I pulled my cousin out of the marsh when he lost control on a section of bob perry ditch, he let off the throttle while trying to manuver and when the motor violently trailed it threw him into the marsh.<br /> me I would run it as designed and pay the 70 dollars a year for insurance.
