witenite0560
- Joined
- Sep 6, 2008
- 216
Ok, here's a stumper for me. So, I'm looking for some background and some help. I've got a 1970, Evinrude v-4, 115hp. I bought it with my boat last summer. Had it out a few times last year and with some tweeking it was running pretty good. Did a little more research and tweeking this spring, both on muffs and in a barrel. Seemed to be running fine and started right up. Finally had a chance to put it on the lake Monday afternoon. Put her in the water, tied up to the dock, parked the truck and trailer, came back hopped in and when I tried to start it, she caught briefly but ran rough like needed some choke, then died. After that she turns over great, but seems to be sparkless. Loaded back up, went home and swapped out for my spare sparkplugs. (Forgot to take the spark plug wrench with me to the lake, but fortunately it's only 2 miles.) Still no spark. So, pulled out my service manual. The manual I have is actually for the 1970 Johnson 115, but they should be just about identical, right? I do have the correct parts manual.
So, I've got battery voltage at terminal #8, 20 amp fuse is good and then it gets wierd..... it tells me to jumper from terminal #7 to #9 to bypass the safety circuit, but #7 has nothing attached to it! So, I read ahead a bit and it says to check that all the terminals on the terminal block are hooked up per Figure. Hmmm, there's some strange things here. No wires where the book says there should be and wires where the book says there shouldn't be and unfortunately some wire colors don't age well, so purples look gray, etc. Well, the next thing to check is the Ignition Safety Circuit Assy. Looks simple enough in the book.... HEY! I don't have one, just two empty screw holes where my book says it should be!
So, I'm thinking someone has bypassed the Safety Circuit and most likely my Pulse pack finally couldn't take anymore and gave up the ghost. Is it common to bypass the Safety circuit in some way? Looks like that would explain why there's wires missing and out of place on the terminal block. Thoughts, suggestions?? Thanks.
