Have a question. Did you drill entirely through the axle for these rollers?
Replacing mine and the holes are only slightly drilled ( blind hole)
I can not find the original hog rings(.177" thick) but can get a little bigger 3/16". But have a problem using the 3/16" hog ring.
Launched my boat and lost to rollers because the new washer with a 1-1/4" bore must have pulled over the old hog ring. When using the new washers which was supplied with the wheels the hog ring won't go into the axle for the wheel.
What did you use to keep the wheels on the shaft?
