Hole shot
jayoel
Currently have vortex 14.5x18 4 blade aluminum. Looking for more of hole shot for tandem ski setup. Is a 3 blade 14.5x19 or 13.25x17.
jimmbo
What Boat and what Engine do you have?
What is the WOT range of that Engine?
What are currently getting for Rpm at WOT?
2015 caravelle interceptor 4.3 merc 3800 Range 4400-4800 spec
Ayuh,..... Welcome Aboard,...... If yer only turning 3800 at Wot, yer severely over-propped, lugging the motor,.....
You need to lower the pitch, 'n get the rpms up nearer or to 4800,....
jayoel
Sorry I am at 4700 wot with 4 blade 14.5x 18 vortex. Looking for a little more hole shot. I tried a 3 blade 13.75x 15 vortex and got prop slip right away. Should I try 3 blade 15x18?
I would try a 15x17p or 15x15p for holeshot. Watch the tach as you would be underproped
jimmbo
Prop Slip, or seriously unloaded Engine?
How long is your boat? Maybe a 4.3 is a bit small for it?
jimmbo
The 4.3 is not going to be a Rocket, or a Speed Demon, in a 21 footer. To get a seriously better Hole Shot, you are gonna need to lower the Pitch to where you will be over revving the Motor, more than a bit, at WOT.
Did you buy this boat new, or used?
UrbanNomadX
Anyone ever try a hydrofoil on a similar setup? I’ve heard mixed reviews, but if it helps planing at lower speeds with a 4.3, might be worth looking into.
Scott06
Try a 16” 4 blade vortex. That is what I used to run for skiing on my old boat. 16” for skiing, 18” for everything else. Worked well and was relatively inexpensive . You will hit rev limiter based on your numbers so when not skiing you have to watch the throttle .
jayoel
I can ski fine with my 4 blade 14.5x18. I maybe using the wrong term. I need a little more torque to start when pulling 4 person tube. So a 4 blade 16inch maybe the trick
jayoel
Or maybe a 4 blade. 13x17
cyclops222
Good speed and yanking skiers up. Do not occur with the same prop.
Taking out a full load of adults ? You would need a possible 3rd prop.
Would require someone to change props. I jump in shallow water. Or do it in the water at the dock.
Or 15x15p.
The issue is getting that large drag load moving. You need a bit of slip to get the RPMs up, and a low enough pitch to pull the load. A single skier is a 400# load. A tube is up to a 2400# load if it submarines
Since tubing is a 20mph event vs skiing at 30mph, I would most likely use a 15p 3-blade for pulling a large tube
Scott06
No holeshot it correct term go down in pitch from your 18”
jayoel
S
