Holiday 18 OB with a 70hp
Snox49x
Anyone have any experience with a 18' Holiday (or similar) with a 70hp outboard? Is this enough motor? I am restoring a 77 Holiday that will be used almost exclusively as fishing boat...mostly trolling. It currently has a 115 Merc TOP on it an runs fine but is not suited to trolling all day. Was toying with the idea of just installing a new Yamaha F70 four stroke (appealing due to it's light weight) vs rigging up a 4 stroke kicker motor. Thoughts?
1973Chieftain
Re: Holiday 18 OB with a 70hp
Welcome aboard Snox! I've not used that set up, but others have similar boats and will give you a better idea then I could.
bunker108
I had a 115 tower on my 18' SS...that motor didn't like to do many things but troll all day was not one of them. Are you trolling too fast? I had a 15p prop and it trolled just fine. I think a 70 might be a little small, but maybe a modern 4 stroke can make up for the drop in HP.
ezmobee
A modern prop-rated 70HP will be a fine motor for an 18' aluminum Starcraft.
roscoe
Had a 18 SS, came with a 1973 Merc 65 hp.
It actually did surprisingly well on that big boat.
I never had more than 3 in the boat, and although a little slow to plane, it did, and she ran out at 32 mph.
ctswf
Sounds promising, I have a 1982 70HP evinrude, I am trying to find an 18' starcraft to match.
Anyone else who has tried a 70hp or less, please post your results
tgp***
Check out this prop chart for a 1967 Merc 650 (65hp), every thing is based on weight, prop diameter, and pitch. The same motor I'm considering using on my 18' Holiday (only because I have a spare, and I don't have the cash to buy a bigger one). It depends on how you plan to use the boat I guess...... If your looking to water ski, most defiantly go bigger. If your looking to fish, and your not in a hurry, should work just fine w/ the right prop..........although I'm a firm believer bigger is better.
For trolling I'd like to find someone who used these. http://www.protroller.com/
ctswf
tgp***, where did you get that? Do you know how I can find a chart like this for a 1982 70HP evinrude o/b?
ctswf
Yes it did help thanks, I have the CLYMER repair manual for my evinrude but didn't see anything like that in it.
I'm sure it would be similar anyway.
airshot
Yep, used to have an 18 open bow with a 3cyl Jonny and it worked great. Towed the kids and adults on ski's and knee boards. With 4 adults we could just squeek out 34 mph on a glass smooth lake, fuel economy wasn't bad either. The 3 cyl jonnyrudes had a weight advantage over the heavier 4 cyl motors, but ran well for a long time.
Airshot
inthedirtagain
I had a 1966 Holiday closed bow with the original 100-s OB (crank-rated). It was a little low on compression @ 100psi, and no matter what prop was on it, I couldn't do more than 32mph. Still, it was my favorite boat that I've ever owned.
