Jrobbs3
- Joined
- Aug 31, 2020
- 20
Hey All - As a covid-19 project, I've been rebuilding an OMC 235/Ford 351 that had been sitting for about 10 years. Engine rebuild is complete and I'm trying to get the carb dialed in. The engine fires right up and then quickly dies due to carb flooding.
Any time the carb has fuel pressure, fuel dumps into the secondary side of the carb, in such quantity that you can hear it flowing/gurgling in there. I've just performed an entire rebuild on the carb including new float (which is adjusted properly) and needle/seat. The mechanical fuel pump is new and I've verified the pressure coming from the pump to be 5.5 PSI which should be fine. Any thoughts are appreciated.
