loco
- Joined
- Apr 25, 2010
- 154
Hi all,
I'm trying to get the accelerator pump set correctly on my carb, but something seems off.
With the carb closed, I set the pump lever to just be touching the adjustment screw base - I can get a piece of paper in there, so can't get any more loose.
However, at WOT, the spring is pushed in, which suggests it's too tight and putting too much pressure on the pump.
It's a standard cam, and I've taken apart the pump and diaphragm, and all looks Ok. The carb had a full rebuild a month or so ago.
Any ideas? Thanks in advance
