I just bought a '91 Reinell, OMC 4.3 HO with the Holly 4 bl carb. The first trip out showed that the choke was way out of adjustment. I had to rotate it 180 degrees to get it to open. It then idled and ran well, but it idled at about 800 and still smelled like it was running too rich. <br />At home I pulled the plugs and found they were not the factory spec plugs, but a "hot" type. I replaced the plugs with the proper type and went back out. It ran about the same... smooth idle, but a bit too fast and rich. I got it warmed up and in gear adjusted the idle down to about 650. It started running a bit rough. I found two adjustment screws (port and starboard) and adjusted the starboard one richer and it smoothed out. I went to the port side and the screw was all the way in! Any adjustment out caused a rough idle. Screw back in and it smooths out.<br />So. Any ideas what would cause this? Did all the previous owners fiddling somehow screw up the carb? Could running way too rich cause this problem? Thanks in advance.<br /><br />Kirk
