Hi Guys, just replaced my fuel pump (http://forums.iboats.com/showthread.php?t=222997) and while I was waiting for answer on the pulse limiter, I decided to put it back together. Did so, had no problems. Put on the muffs, won't turn over!!
I checked the battery voltage (good), took off pos battery cables, re-hooked them. Checked my battery cables going into the engine, no problems. I can hear the choke working when I push the key in, but that's it! I checked all wires around where I was working to see if I popped one out, looked good. The only wires dealing with the fuel pump are the 4 wire connector, which was disconnected before anyways (maybe deals with VRO?), so I tried plugging it in, still nothing. Having a bad day.
I know this sounds stupid, but is there anything I need to do after installing a new fuel pump in regards to electrical?
thanks.
1996 130HP Looper
thanks.
1996 130HP Looper
