Hi guys new to this site and have what to you guys is probably a dumb idea, but here goes. I own a 16ft j-series skiff with a late 80's model 40hp johnson. I don't have tilt and trim and with flounder gigging and my back not getting any younger I was wondering if anyone else had any expirience in building a tilt and trim unit out of a set of set back plates. I can't figure out the dimensions or angles at which I should mount the cylinders or the linear actuators. ( checking on the actuators soon) Also don"t know if it would be possible to remove the bottom bolts and install bushings in the top holes and use them as the pivot point for the tilt and trim unit. How do I determine the length of stroke and amount of force needed to raise the motor. Also if using the linear actuators will they hold up using them to trim the boat. Another thing that comes to mind is I use the boat in salt water a lot.
Any input form the guru's sure would be appreciated. Thankshttp://forums.iboats.com/images/smilies/confused.gif
