Mischief Managed
- Joined
- Dec 6, 2005
- 1,928
I had a really stuck bearing carrier that would not budge with the Mercruiser tool. I discovered that 3.5" (4" OD) Schedule 40 structural steel pipe was a near perfect fit to make my own tool. I bought 2 feet of it, cut 4 slots in one end to fit the bearing carrier, and ground the ID a smidge so that the fit was not crazy tight. I then welded a plate on the opposite end and welded a 35 mm nut to the plate so that I had something for an impact wrench to turn. Required a 1" square drive drive impact wrench and a lot of heat to get the thing out, but it came out.
