Re: Home made o2 sensor harness?
yes, just push your meter probes into the back of the 02 sensor plug where the 02 sensor wires plug into the motor. One pair are for the heater and will read well above 1 volt... 12 maybe.
The other between 0 and 1 volt.
When you've found the correct wires you could buy suitable plugs or splice but the proper harness is cheap so why.
Pushing in the back will get you out of a bind
