Has any one ever made their own pontoons. I have the chance to get (free) seven 20' lengths of 12" fiberglass pipes. I thought of possibly using them for pontoons and build a deck for a pontoon boat. would they work? I was told the they will support the same amount of weight that they will displace in weight of water, but they will be just under the water. If this is true:
the volume of each pipe is: 15.7 cu ft
times 6 pipes, three each pontoon=94.2 cu ft
times the weight of 1 cuft of water(62.5lbs)=5887.5lbs.
Is this correct?
so could a pontoon deck be built with these or would it be a waste of time.
Is this correct?
