Re: Home Made Test Tank
I've been playing with a similar idea myself, so here's my 2 cents -<br /><br />Since the tank is at least 4 ft high, and the average small motor that you could run in this size tank only would probably only have a 25" leg (bottom of transom clamp bracket to top of anti-ventilation plate) you'llneed to add another 18 inches or so to clear the prop from the bottom of the tank. Cut the opening in the front and forward/top part of the tank to accomodate this and build a frame around it.<br /><br />You could then angle the "transom board" to simulate the exact running position of a motor on the boat, you could cut out an over-flow drain at the appropriate level and, you could add the "stove-pipe" style ventilator to the top/back of the tank to vent the exhaust/smoke.<br /><br />I don't think I've done a very good job of explaining myself here, but if you've ever seen a quality tank at a dealership, I think You might get the idea...<br /><br />-John
