fishfeatures
- Joined
- Mar 29, 2011
- 743
I made a working replacement box for my T&T that i added to my 60hp johnson 1990
I also added a remote t&t swith which will be fitted to the wheel
Now all this worked fine in the garage, I wired it all up and then to the motor and it worked perfect. Today I installed it in the boat and gremlins must have been about as all i get when pressing up is a click and a audible "beep or horn " on the down.
The power is coming from the fuse box with a 20 amp fuse, to the relay box under the dash. The switch and box are being powered from this supply , then motor is wired to the box , switch to the box and it is grounded back to the negative bus bar.
I am suffering from "electrical block " at present and I can't figure out where my prob is.
Any help appreciated.
