wildmaninal
- Joined
- Jul 14, 2007
- 1,897
I've been thinking about, toying with, plotting on, pondering with, scratching my head about, measuring, on building a truck camper. I grew up with a truck camper for use on family vacations. I really like the idea of being able to pull my boat while hauling a camper. My truck is a short wheel base 2006 F150 Ford. If I was to build this camper I would not want it to extend out beyond the bed of the truck, if I did extend it out it wouldn't be much.
Thing is I am low on funds and I am just pondering on what materials to use, how to lay out the floor plan. I've seen some nice truck campers and actually saved a few pictures and jotted down some info. I was thinking that it would be killer to build the frame out of aluminum but I don't know how to weld aluminum, I don't know how easy it would be to come by 2x2 inch aluminum tubing, and how much it would cost. But if I made the frame out of aluminum the camper would last forever. We do have alot of lumber around, I would half to cut to width if I decided to use lumber instead of aluminum. We have alot of 2x6s is what it boils down to. I could take the wood and paint it or stain it to seal it after cutting it to size, maybe it would help it last longer, I've done that on a boat recently. 2"x2" lumber would be sufficient for the framing I believe, but I have also thought of going with 2x4 but I don't know how much weight it would add. Weight is also going to be a big factor if I decided to build this.
My cousin mentioned using fiberglass for the outer walls, I don't think that would be a great idea plus it would be expensive. I believe aluminum siding would be the best route.
I have parts from a couple of truck campers that I stripped recently, might even have a stove to put in it, I already have a sink, I even have a door. Thing about it is I don't know how the law would react to me putting lp (propane) in a homemade camper.
Another few reasons I would like to build one is because I can't afford new, you can't find a short wheel base truck camper, and if I built it I know what it is built of.
Here are some measurements, and a diagram I drew up. Sorry about the size. Any thoughts?? Ideas?? Any Input would be greatly appreciated.
