Gents,<br /><br />My boat (22' aluminum approx 3500lbs) was loaded down today pretty heavy today and I noticed that my engine had exhaust smoke, or steam, blowing around down low, at the upper part of the lower unit. Kind of where the lower unit meets the engine cowling.<br /><br />There was water coming out of the 'pee hole' but earlier in the day the hole had been plugged up and I had to clear it. My boats a drop bow and I have landed on the beach several times in the past couple days. So I thought it just had a little sand stuck in the hole. The 'overheat' light never came on, and the engine ran fine.<br /><br />This engine falls in the cracked block serial number range, but since it was bought in Canada there's no warranty. Honda of Canada doesn't even acknowledge the crack problem.
Plus, the engine has 1060hrs.<br /><br />So while I'm not happy with the amount of water coming out the 'pee hole' I don't think it was overheating. I'm thinking the extra load on the boat today (approx 1000lbs) was 'working' the lil'130 more than I ever have before and perhaps it burns some oil when weighed down? I've only owned this boat for a couple months, so I'm still learning it's quirks. I usually turn 4000-4500 rpms with this engine. Today was no different, except I was only doing 20-24mph as opposed to 26-29mph unloaded.<br /><br />Am I lugging the engine by not turning 5000rpms?<br /><br />Thanks for any thoughts you may have.
