Honda 130 stern tube lube
lazza803
I have a 130 hp Honda andsterring is stiff. There is a grease nipple for the lower bush but cant see anything for the top one. I have hydraulic Hi drive.
Any hepl out there?
lazza803
Hydraulic HI Drive. There is grease nipple for lower swivel tube bush.
Cant find way of greasing upper bush.
Any ideas? Cheers
MattFL
Can you post a picture? All motors are different, but my Honda only has one zerk on the steering shaft too, but if you pump enough in it comes out both the top and the bottom. Have you tried pumping grease in until it comes out somewhere?
lazza803
Hi. Figured that might be the case. Fair bit came out the bottom so I stopped. Motor was tilted up when I did it. Will try putting jack under skeg to reduce the gap in bottom bush so grease can go up. There are two holes at top bush where grease could come out. Owners and workshop wasnt that much help except lower grease nipple was identified as grease point. Will update with any results. Cheers
lazza803
So put upward pressure on skeg. Had less grease leakage out of bottom but just built up pressure in tube and grease came back out of nipple which I destroyed in the process. Am trying to get some wd40 into top bush through the two holes in the casting. Am using a long bar strapped to the gearbox to work it in. I think it has loosed a bit so will continue with that for a couple of days.
