Honda 2 hp Clutch
abdiver7777
Last time I was scooting around in some kelp and didn't realize the prop got wound up in some. Afterwards the clutch didn't want to engage so had to row a few hundred yards. Got home and put it in a barrel and seems to work ok but doesn't sound the same.
Any ideas if this is an easy fix or if it is a problem?
hondon
Re: Honda 2 hp Clutch
Have you removed the prop to inpect the shear pin?They can break but catch occasionally.That clutch is under the powerhead so repair rivals the cost of a new engine.Hope for the shear pin.
abdiver7777
I didn't think to check that.... I figured they are either broken or not...
Will check tonight - Thanks........
abdiver7777
Pulled the prop and sure enough...... shearpin was in 3 pieces..........
Awesome-------Thank you!
