Honda 225 extension kit
Status
Not open for further replies.
davecharles
Does anyone make an extension kit to make a 20" 225 honda into a 25". How much do they cost?
hondon
Re: Honda 225 extension kit
No kits that I know of for anybody in that HP range.Pretty much need to know what you need and run with it.
rbmurphy_ak
Honda will sell you the spacer, drive shaft and gear shift shaft necessary to accomplish this. Expect to spend some dollars. The drive shaft alone lists around $700.00.
hondon
Those parts are certainly available as indivdual units ,but a kit is not out there.Changeing that driveshaft will mean rechecking shimming and lash on all gears .Not a huge deal ,but why?
rbmurphy_ak
Here's my reason why: last fall a number of 225 engines became available at extremely low prices, like 9k, brand new. I bought one as a spare, with a 25 inch shaft and counter rotating lower unit, and will be converting it to a 30 shaft. Saved me a bundle. As more used motors hit the market, I'm sure folks are looking for ways to shorten/lengthen to fit a boat the own or plan to own. Incidentally, I am looking for the spacer for a 30 inch motor and have a 25 inch spacer looking for a home.
  • Like
Reactions: Pin
Pin
I’m looking for an extra long shaft 25” to convert my Honda 225 hp from long to extra long. Is it still available ?
Sea Rider
Leg convertions are costly ones. If plan swaping one 20 shaft motor where a 25 shaft one was previously used, why don't you cut the 25 inch transom to a 20 inch one if transom permits whether a DIY work or with someone who can perform such work.
Happy Boating
GA_Boater
Your local dealer is a phone call away and still in business unlike this thread from 2005 - 14 years ago.
Or you could start a new thread and tell what boat the motor will be used on. It'a a little early to start cutting her up without some particulars.
Closed.
Status
