Re: Honda 225?
Thanks for you answer. I called Cap Sante Marine and spoke with the yard mngr and he pulled the bulletin and he said it is a big job and Honda is not doing anything with the motors that do not have problems. My motor is mounted high on my transom, (could not go any higher w/o a jack plate) I am mounted at the top of the engine mounting holes. I had to go that high to correct a proposing problem, along with a transom lifting 4 blade Power Tech prop.
I have it documented w/ the installer in case something should come up and I still have 3 1/2 years of warranty.
I goggled the bulletin and found a lot of info over on another forum.
