Hi,
I have a 1999 30HP 4-Stroke Honda on a 15ft Aluminum fishing boat. When cruising at lower speeds if you apply full throttle the motor bogs as if it was going to stall. If you back of to 3/4 throttle it runs fine and gradually picks up speed. Once the boat is running at higher speeds you can then go full throttle and it's fine. Basically the symptom happens when ever there is more load on the motor and you open up the throttle.
Any suggestion?
Thanks in advance,
Paul
Any suggestion?
Thanks in advance,
Paul
