Hi All,<br /><br />I was out last night and got into some murky water (organic bottom debris cloud) and all of a sudden the water pump tell-tail went from clear, to brown, to sputtering, then stopped altogether. ('00 Honda 40hp) I immediately shutdown the engine, and pushed myself back out to clear water. I tilted up the engine, but all the water intakes are clear and everything looks normal. I fired it back up, but still no water from the tell-tale. I get into this type of situation quite often since my lake is very shallow and heavily overgrown with shoreline weeds, not to mention those nasty alligators
Normally, just getting back to clean water solves the problem, but this time it didn't.<br /><br />My question...has anyone ever heard of something like this where the intake screens look clean, but the water passage seems blocked? I've checked the tell-tale tubing and it clean. I put a new impellor in a few months ago. Water pressure was strong. I just find it odd.
<br /><br />Once I pull the boat from the water, I'm planning of using the the flush fitting on the bottom of the lower unit, to blow clear water through the cooling passages. If that runs clear, and it still wont pump then I'll pull the lower unit and disassemble the waterpump.<br /><br />Oh the joys of southern lakes....<br /><br />Nav
