The buzzer alarm of my Honda 50 has started to activate although both the oil and temp sensors appear to be working. Water comes out of the pee hole and oil level is fine. The alarm only goes off once the motor is in gear and the throttle is moved past a slow troll speed position. The alarm sounds whether the engine is running or not; the key simply needs to be on.
I have checked across the sensors and they appear to open and close the circuit as they should. Have checked to see if the movement of the throttle control "pinches" a wire in the control housing or at motor but nothing appears out of order
Could it simply be a bad buzzer? Why would it only come on when throttle is engaged?
Any help or suggestions for diagnosis would be appreciated.
john
john
